how do i transfer these files?
6 replies · 1,704 views · Started 07 November 2002
sorry but it may seem like a stupid question for most of you, but bare with me, m just new to using A 9210. how do u transfer videos (NIM) files to the 9210 from my PC. is it an option in the pc suite? ive tried to look but cant seem to find it.. pls, someone take the time to post detailed instructions here... thank you very much ! 😊
Once PC suite is installed and setup you should have shown in windoze explorer under your desktop: My Computer, Network Neighbourhood, Nokia 9210 Communicator, Recycle Bin. Click on the communicator icon and then you are looking through the storage on your 9210 (I recommend using the cable for large data sends, as IR tends to stop sometimes).
hey thanks dude! found it! hassle, i feel so stupid for not seeing that! 😊 thanks again
[quote="4u2nv"]Use a USB device that cable takes years![/quote]
Yeah... totally agree with u... by using an MMC READER u can transfer a 5MB nim in seconds...
There is a great device made by AcomData called the multiFlash. It lets you write MMC, SD, CompactFlash, SmartMedia, and memory stick.
[quote="Cybernetski"]There is a great device made by AcomData called the multiFlash. It lets you write MMC, SD, CompactFlash, SmartMedia, and memory stick.[/quote]
I use a PQI device that reads 5 devices` including microdrive.
It is very useful yf you work with 2 computers, but this is another issue.
