Operator Logos
21 replies · 4,111 views · Started 08 November 2002
If there are some people asking for some cool collection of operator logos, here's my contribution.
Hope you guys like it. :angel:
how can i send a Operator logo or Picture msg by IrDA?
if i send it as .bmp to any nokia phone( 6210, 6310, 8310.. ) doesn't work ?
i'm using MyStyle now, but u must send them by a sms!
any way??
Enrique, I guess that was the only way and the purpose of it, by sending via network. or else you can use IrDA with Logomanager.
[quote="Anonymous"]Enrique, I guess that was the only way and the purpose of it, by sending via network. or else you can use IrDA with Logomanager.[/quote]
Yes! I use Logomanager to send via IR as well to others Nokia phones. :roll:
Yes it does, but you need to change the 9210 to use FBUS connection instead of Serial, and you do that in Netmonitor, which you activate by using an MBUS cable and logomanager.
HTH
Besides the operator logos, I have several wallpaper collections as well. One problem is that they are too many/ large to zip and to attach. Dont have a website yet. I am currently making one. Any one has a suggestion on how I contribute these wallpapers? I tried posting some on Patrick's site but it will take ages before I post them all.
Hi apcaw, can you please split it to a smaller sizes therefore you can share it here. :P thanks in advance.
[quote="N9210"]Yes it does, but you need to change the 9210 to use FBUS connection instead of Serial, and you do that in Netmonitor, which you activate by using an MBUS cable and logomanager.
HTH[/quote]
Yes! a better idea by changing it to FBUS mode rather than serial. 😉 However, it situated in menu 31 from the netmonitor. thanks..
[quote="apcaw"]If there are some people asking for some cool collection of operator logos, here's my contribution.
Hope you guys like it. :angel:[/quote]
How do you transfer one of these to the front screen of your 9210i? :roll: :roll:
[quote="N9210"]Either by SMS or Logomanager if you have NetMonitor enabled on your 9210[/quote]
How do I save one of the logos in messaging and send it as a sms message to my own phone?
Do I need some picture messaging software?
You need a program to use the logos/ pic msgs. You can use MyStyle or Emessaging. Both works fine. With MyStyle, you can use the logos automatically without sending it first to yourself. Its more expensive, though, compared to Emessaging.
using MyStyle
Operator Logo ==> New ==> Options ==> insert logo from a file ==> Browse to the logos ==> insert the logo ==> Options ==> set logo to phone.
That's it
Regards 8)
Fortunately I have an 8310 aswell as a 9210 so i just put in a spare sim in the 9210 then use logo manager with my 8310 via IR and send them this way,if any of you have a spare phone with an IR port give this a try 😃
