Faulty 6600 switch.... anyone else had this problem....?
1 replies · 2,296 views · Started 18 July 2005
I've had a 6600 hundred for a while now and had a few complications with it but nothing serious, a few software glitches and crashes the usual you know. Then the other day I was about to turn my phone off to put it on charge, they seem to hold a better charge when done this way, and to my horror it wouldn't turn off. I've tried for days now to resolve this problem but the only solution I can think off is a fawlty/broken switch. I'm just wondering if anyone else is having/had the same problem and if you've had it repaired how much was the cost. I'm from the uk for reference and pricing...
My 6620 actually wouldn't turn off one time, so I ended up taking out the battery (!) to turn it off. I put it back in and it worked fine, and I havn't had that problem since then. Probably not a good idea to turn it off like that, though.
