HI, ive just got a 6680 on o2. Im having problems with it saying "Memory full. CLose some applications and try again". I can solve this problem by turning the phone off and on again but i dont want to be turning it on and off 3 times a day just so i can use the camera, internet or an application. How can i solve this problem? im using firmware v3.14. Another thing i dont understand is when i use my camera it says i have only 11 photos left and 5.47minutes on video left. But surely since my phone is brand new i should have more. Im using a 64MB standard mem card. Help any1? Cheers in advance
Error message "Memory full. Close some applications and try again"
to see how memory left, try tools -> memory it's show you your usage of the RS MMC
to see how memory left on the phone memory try Fexplorer or go to contact -> options -> contacts infos -> memory
to take more picture or videos,try to free memory or drop the picture or video quality
for the lack of space in a brand new phone, it's due to pre installed apps
meastwood98 wrote:HI, ive just got a 6680 on o2. Im having problems with it saying "Memory full. CLose some applications and try again". I can solve this problem by turning the phone off and on again but i dont want to be turning it on and off 3 times a day just so i can use the camera, internet or an application. How can i solve this problem? im using firmware v3.14. Another thing i dont understand is when i use my camera it says i have only 11 photos left and 5.47minutes on video left. But surely since my phone is brand new i should have more. Im using a 64MB standard mem card. Help any1? Cheers in advance
Check to see if it's your phone memory or MMC memory that is full. If Phone memory transfer some files to MMC. Ringtones, Videos, etc. Also set Camera and Video to use MMC instead of Phone memory.
Download the installation files for Nokia programmes from here Nokia 6680 Downloads
Uninstall some of the applications via Manager and then reinstall and load files to MMC instead of Phone memory
Hope this helps
Cheers thats a great help. How do i make my camera use my MMC?
Just another quick question. Ive been to that web site and can't find the applications to download. Could you tell me where abouts they are if thats possible. Cheers
meastwood98 wrote:Cheers thats a great help. How do i make my camera use my MMC?
i think its one of the options, go to camera then settings and when you scroll down i think you will find whether to use 'phone memory' or 'memory card' i think
Ok ive done that now. cheers! Now i mwondering when i check my memory it says im using 1873Kb of phone memory but only shows 19Kb for contacts and 2KB for calender. Where is the rest of the memory being used? Its the same kind of thing for the momory card aswell. Another thing i have heard of some software called tracker, apparently it helps control applications- does any1 know anything about this? Cheers for any help in advance!!!!
meastwood98 wrote:Just another quick question. Ive been to that web site and can't find the applications to download. Could you tell me where abouts they are if thats possible. Cheers
Ok try this link
Check PC Software and Phone Software
meastwood98 wrote:Ok ive done that now. cheers! Now i mwondering when i check my memory it says im using 1873Kb of phone memory but only shows 19Kb for contacts and 2KB for calender. Where is the rest of the memory being used? Its the same kind of thing for the momory card aswell. Another thing i have heard of some software called tracker, apparently it helps control applications- does any1 know anything about this? Cheers for any help in advance!!!!
The memory used by applications are not reported. Check the manager application in System folder. Highlight an application and view details. That will show if application is using Phone or MMC memory. Big ones are Quick Office ! and Adobe
Ok so all my applications are on my memory card, which is good. Do applications run in the background on 6680's? Its just my phone sometimes runs slower than others and thought maybe this could be why. If they do is there somesort of task manager software I can get? Or is it just the phone that sometimes runs faster than others?
They do run in the background. On the 'desktop' hold down the menu button for 3 secs, this will then show you what programs are running in the background.
It will be 'telephone' plus a few others, scroll down to the ones you want to end (everything but telephone) and press 'c' to end them.
Job done.
Hope this helps. Thats the reason you get the error messages nothing to do with running out of physical space. That would only happen if you were saving something.
Im I ok closing the messaging one? or will this stop me recieveing texts?
Yeah you can end it. It just means your inbox is open in the background. You can try and end 'telephone' ... but it won't let you 😊
Cheers, thats a great help!!! Any other tips on how to make my phone run/work better/faster?
Not really, only had mine a week 😊.
Its not a really complicated operating system like windows etc, so I would say, close programs when not in use, delete things when you no longer need them, such as apps and SMS messages. Just keep it streamlined. Maybe format your memory card every few months. Make sure you back everything up because a format will delete everything.
You could delete apps like currency convertor and image editor and PDF viewer etc if you don't use them but whether this would actually speed up anything is negligable. I like to have them all on because it looks cooler.
Is your phone noticably slow. Mine seems faster than my old K700i. If it is very slow, take it back to the shop and see if you can compare to a working one.
i have the same problem, but mine is related with the messages... if you have lots of messages the phone will be slower and slower until it starts displaying that message... although you have 8MB free in phone's memory and 30MB free in the memory card! I would like to know if anyone have experienced this problem.
i have been using this phone for 4-5 months and this is my unsolved problem since day 1 i got this phone. i've unstalled fexplorer and app manager to tracked the ram memory status. even though all files that were open are closed or exit, the ram memory still keep running lower and lower as i use my phone until i cant open any new files and it'll says 'memory full, closed....'. then gotta reboot the phone to make the phone goes back to normal. sometimes have to do this 6-7 times depends on usage. this has nothing to do with phone memory as the reading is very constant as about 7plus mb when ram memory runs very low, seems like the ram memory is not cleared even though all files were closed or exit. brought it down to nokia, formatted twice(phone and mmc) but still they cant solve. now there is this few here this problem, are there some more who got this problem?
Just simply closing all the open applications by holding down the menu key solved the problem fine for me. Sounds like your phones got something up with it. Try speaking to nokia or whoever you got the phone from!!
meastwood98 wrote:Just simply closing all the open applications by holding down the menu key solved the problem fine for me. Sounds like your phones got something up with it. Try speaking to nokia or whoever you got the phone from!!
that doesnt solve any problem like this!
just try to have 3000 messages stored and you will see how this problem afects all symbian phones!
Barros wrote:that doesnt solve any problem like this!
Could be the messages. I've had phone for 4-5 months and never had this problem. I don't keep messages though. I have about 15 stored.
Why do you keep so many ?
3000 messages????? [splutters]
Why on earth would anyone want to keep 3000 text messages stored on a phone? Text messages are transient things at the best of times. JUst archive any important ones and zap the rest and your phone will work properly.
And yes, good advice from others about keeping the RAM free of certain apps which like to hog the processor (games and music players and camera).
Steve Litchfield
Some problems solved, some not. Ive had my fone for a day and i installed Asphalt GT on it. Tried to run and came with the same error. Ive put my camera and video to write on the mmc, uninstalled ALL applications on the fone and the mmc that i can and even changed the message settings to read off the mmc too.
So ive only got Asphalt GT on the mmc and it has 47MB of free space left and still no go. Whats even stranger is that the game runs on my 6600 no problem!!!
I fawt the 6680 is meant to be more powerful than the 6600??? So whats that all about???
Any takers??
hey,
i have buy it recently, i have not stored many things in memory card(64mb) and phone but i am facing same problem, in start my all things are ok i.e...messages but now when i send message it moves to outbox and shows 3 minutes waiting and then message message sending failed when i see its reason "General memory full. Close some application and tr again".
my all messaes are stored in memory card and near 30mb is free, why this problem is coming ???
please do some solution ...
looking forwar all of you to find its solution . . . :icon14:
hey no one here who can help me ??
or should i sale my phone ??????????
