Internet for 6260
3 replies · 2,398 views · Started 18 July 2005
chris_0000 wrote:Can anyone tell me the settings to access the internet from the nokia 6260 via bluetooth
You can find something in this site,
Goto Support and setup instructions for Nokia phones section and read them carefully,
I also tried them, i had connected to pc using dial-up or Lan, but no packets transfered between PC and Phone.
I have Nokia 6260.
If you found something new about it please tell me too.
This link is for infrared, USB and Bluetooth Connection to PC.
Hope it would be useful.
Hey,
same problem for me 😉
As I red on many sites about using internet on nokia phone via bluetooth you need to use Bluetooth Serial Port to get that to work. And afaik (according to that sites) Nokia 6260 doesn't have that function. Which seems pretty weird based on my experience. I have Bluesoleil bluetooth device which uses pretty good connection manager that shows which of services are available on your phone. So when I discovered at first my phone via that manager it showed that my phone doesn't support Bluetooth Serial Port but when I connected to my Nokia 6260 using Nokia Pc Suite and checked again it shows that Bluetooth Serial Port is active. So following I'm looking for any possible way to get that to work. Tried almost everything besides that thing called "gnubox" which I heard f*cks cellphone sometimes.
