Changing application icon
4 replies · 6,370 views · Started 21 July 2005
Hi there,
i do not like that application icon and so i decided to replace it 😊
Now, i have installed a small prog called Executable File Icons Changer.
I can import from my PC collection a specific icon but i'm unable to find the program in NOKIA E:\ via PC Suite File manager ( i cannot find SYSTEM\APPS folder, where prog should be located :cry:
Can anyone please help me?
Thanks in Advance
lsangio 😉
It doens't show them in Nokia PC Suite so people can't tamper with system files and damage their phone.
Download File Explorer from the net somewhere. I can't find it atm.
This allows you to see all the hidden folders including the apps one you want.
Edit:
http://users.skynet.be/domi/download.html
If you need any help using it just ask 😊
Thanks for posting.
I already have FExplorer on my 6680.
What i need is a PC prog to explore my phone memory card...
PCSuite (as you see is not adequate :frown: )
Thanks again
lsangio 😉
Thanks.
Now that i can deeply see into my memory card using a card reader, how can i locate my "icon file"?
I browsed the entire MMC stuff using both Microangelo and Executable File Icons Changer but had no luck at all :frown:
For example, in my System\Apps\SlovoEd folder can't find any executable but only SlovoedEng.dll !?! Where is its icon located?
EDITED
Ok, i have to edit .AIF file using AIF Builder; now, where can i find this prog?
Thanks again for helping
lsangio 😉
