Hi guys.... I want to know how to format N9500, and how to reinstall again.... sorry new user......
Max
Max
Format:
Close all applications, turn the phone off and take out the battery. Put it back in after a couple of seconds. Open the Communicator. As soon as the blue NOKIA text disappears (the screen will become completely white), press Ctrl+Shift+F. After this you will get a message whether or not to format the phone. Press the top command-button on the right side of the screen to format the 9500, the bottom command-button to continue booting normally.
To completely get rid of all additional installed programs, delete the entire \System folder on drive D: (your MMC card). If you cannot see the system folder in File Manager, switch it on by selecting "Tools"-"Settings" from the Filemanager menu and set "Show system directory" to "Yes".
Reinstall:
You don't have to reinstall the standard software since it is located in ROM. After the format, all your programs (Word, Sheet etc) are still there. You probably do need to reinstall all third party applications.
HTH, Arjen
er..
just want to confirm before formating the 9500.. is that really don't need to reinstall the standard software?so after format the 9500,it will be fresh new system rite?automatically install or any additional info or guide to this?i really2 newbie around here..sorry..
actually i really afraid to format my 9500..but i follow ur guide..then my 9500 back to normal(fresh)..tq.. 😊
