Hi all,i was wondering if someone could please give me an advice: i have a 9210i,for work i need to recive images that are quite heavy. I've installed switcher as Dazler told me to help the 9210i. But since i often need to move these images from pc to 9210i these images tend to be really heavy. Now,is there a way or a program that allows me to make them lighter so that i can open tthem without waiting ages?Often the 9210i won't even open them! Thank you very much! The Godfather. :-?
Searching for advice
what do u mean by heavy?? >>500 KB?
you can view them in the Imaging without openning them..
i didn't heard about a program like that.. :roll: sorry.
500,even more...but i need to open them 😞
You can always resize the images on your PC. But I guess that's not an option. Try using mbm files instead of jpg. It requires more diskspace but if I'm correct it wll display using less memory.
Thank you very much Dazler!!!!!!!! 😃 I'll try to do how you said!
I believe the original images is in high-resolution...(perhaps 300dpi or higher...) by using a professional image editing tools( for me, i use photoshop...) u can change it to a smaller resolution...(like 72 dpi..)
Anyway, my fav. imageviewer for 9210 would be ialbum.. its pretty neat... (u can do slideshow for presentation...) i also have gipviewer, anigif and myphoto... but nothin beats ialbum...
Hi Nosferatu. You hit the point! I'll go get photoshop today and try it!!! For my 9210i you suggested a couple of programs...i don't own a credit card,how can i buy one of these programs from internet? Or is there a chance that some of these programs are freeware? Thanks...The Godfather. 😊
Well... all of them are not FREE but u can always try their DEMO VERSION... 😉
Ok...thank you so much for your advice!!!!!!Thanks even to Dazler and Enrique!!! 😊
No problemo... but pls update on what's your final choice... 😉
I've downloaded ialbum. I'll try it for a few days...and as soon as i figure out a way of paying i'll let you know! Any suggestions on the payment method? It's the first time i have to buy something from the web!!! 😮ops:
Wow...ialbum is really exellent!!! 😃 .I've just installed it and it has already convinced me 100%!!!!!!!!!!!!!!!!!!!!!!!!The trial version is limited but it gives you a good idea of how many things you can do!Thank-you! 😉
😃 Yeah, IAlbum is the ultimate imaging tool it seems... and i think it's the fastest image viewer on Nokia 9200 series Communicator... It supports viewing of BMP, GIF 87/89a (including Animated GIF, multiple frames), JPG, PNG, MBM (including multiple frames), TIFF (including G3, G4 Fax); Max. resolution up to 2560x1920 (depends on your memory)...
p/s: Also supports slide show in manual or automatic transition; very cool for presentation... 😉
[quote="The Godfather"]Any suggestions on the payment method? It's the first time i have to buy something from the web!!! 😮ops:[/quote]
Well... u can always get your :angel: friends :angel: with creditcards to purchase it for u and u pay them the cash later... thats how i do it during my early days... 😉
Well now I know next time I can advise on getting IAlbum 😊
yes, this is a very cool apps... I am using it as well.. :fadein:
Hi guys,i'd like to buy some software from the software market. My question is: how do they let you download the software? In other words:is there the possibility of installing the software on more devices or do they let you download only a special type of version just for one 9210??! I'm asking this because I have 2 communicators. Thanks!! :P
there are some softwares that will work only on 1 communicator using it's IMEI, and the others work with a registration code only 😉
...so i'll have to buy 2 software's for 2 different communicators!!?! 😞
If u are referring to ialbum then YES u have to purchase more than 1 coz it's reg code are based from you IMEI... u can always PM me to know which app is IMEI based and which are not... 😉
p/s: not all apps are based on IMEI...
Hello everybody. I have another fresh question:I'm noticing that my 9210i has became slower especially in my agenda and my messages applicatins. My c rom is completely empty of anything for exeption of the pre-installed applications and my phone database. I have an original nokia 64 mb mmc on which i have insalled add-on softwares and where my data is stored.It is not completely stuffed with files or other things. I have installed switcher to use better my memory,but... Any suggestions? Thank you very much!!!
u should actually post this as new topic so that u'll get more replies...
anyway, since i'm already here... well... it's not totally abt empty c drive that makes your 9210 runs faster... it all depends on what apps u use/installed... example:
if u have activedesk, smartmemory, smartsecure, erecorder and all those memorysuckers apps installed/active... your 9210 will definitely get slower even when your c drive is empty... 😉
more or less space on the C rom doesn't make any difference ... This isn't ram, the 92xx doesn't use this memory. THe symbian os doesn't have anything like virtual memory ... so c empty or full ... it would make much difference in speed.
...but how can i check on how much ram i'm using? I mean: programs like switcher or appman will do it? Thanks
task manager/switcher/appman/smart memory ...
Thank you Dazler! 😃
I try to be useful 😉
