I've read somewhere about tips & tricks for the Nokia 9300..
one of them was: *#92702689# which shows a call timer that cant be reset(in minutes), a call counter (number of calls made and recieved), and a standby timer (in minutes)
it works.. However, Since then, I can't log to any option in the phone side.. every option I tried showed me the same screen of the call timer..
What I can do ???
If I format the device, should it help???
What is the latest firmware for the Nokia 9300, & how can I update it??
my firmware ver. is 4.53(00) 22.12.04 RAE-6
waiting for ur reply..
Thanks in advance..
Latest firmware is 5.22. Your nearest authorized Nokia service/repair center can update it.
Simply switching off the phone and switching it back on again should solve your problem
Arjen wrote:Simply switching off the phone and switching it back on again should solve your problem
Didn't help ! tried it several times didn't work !
Any other suggestions?
about updating the phone.. can I do it by the USB cable?, if so, how to do it !
This phone is not supported by the Nokia provider in my country (I bought it abroad)
sahmedkh wrote:Didn't help ! tried it several times didn't work !
Any other suggestions?about updating the phone.. can I do it by the USB cable?, if so, how to do it !
Not recommended to do the firmware upgrade yourself AND you need a bit more than your USB cable to do it. If no nokia reseller that supports, then you are kinda screwed 😞
Joe9500 wrote:Not recommended to do the firmware upgrade yourself AND you need a bit more than your USB cable to do it. If no nokia reseller that supports, then you are kinda screwed 😞
Thank u for your fast replies...
I formatted the device & it works again...
