Answering Calls Nokia 9290...
6 replies · 2,340 views · Started 09 November 2002
If I receive a call when my Nokia 9290 cover is closed. How do I answer the call by simply opening the cover? Or does this phone not do that? I want to be able to automatically answer calls by opening the cover? Thanks in advance!
I don't think that is possible..
It's you have to use the answer key.. :cry:
wait till you see others posts.. they are all brilliant here 😉
I think the quickest way is to press the green answer button on the front of the phone, THEN immediately open the cover. Try that... 😃
Perhaps you can try using the "Netmonitor", but it can only answer it automatically when the phone rangs. not when you open the cover.. 😞 too bad.
The phone rings, I flip the cover open, and press the upper-right key on the screen that says "Answer." 😊
If that doesn't appear, press the Telephone tab and press the upper-right key that says "Answer." 😊
