just bought my 6620
2 replies · 2,198 views · Started 13 August 2005
is it possible to transfer documents from my computer to my 6620 using my usb cable? How do i do it with pc suite?
Open up PC suite, go to file manager (psst you need your phone connected before opening PC Suite in case you didn't know) and browse to the files/where you want to transfer the files. Open a new My Computer window and browse to the folder you want to transfer the files to/from. Then just drag-and-drop between them.
You should have made a second post rather than editing the first one, I almost ignored the thread since it still said my reply was the only one. I know I am double-posting but given that days have passed I think it is reasonable.
