Orange uk mms on pay has you go dose it work?
2 replies · 4,733 views · Started 11 November 2002
has anyone on orange uk pay has you go got there mms to work my nokia 7650 is set up right but it will not send them even orange was stuck for a answer when i rang them 😞
the software version on my phone is 3.12
Im not sure about Pay as you go but I have a contract phone and the MMS works fine, I can't see why pay as you go should be any different.
i have pay as u go and mms works fine im on orange and my phone is 3.12 have u access points set up on my settings i have goto messaging click options settings multimedia...preferred conection orange mms sec con.orangemms...always on /retr immdiatly/.anon mesages no/adverts/yes/reportsyes/validity24hrs/image small....then go to tools/settings/connection/access points...name Orange MMS/data gprs/apn/orangemms/user orange/password prompt no/password Multimedia/authentication normal/ gateway ip 192.168.224.10. homepage mms.orange.co.uk/securty off/session permanent
sorry if this is long but was reading off phone
