Fix It up!
43 replies · 4,865 views · Started 11 November 2002
Oh and Rafe, I've tidied up the mess around that hole in the forum where my Avatar should be, it's a little neater now 😉
Damn you,you stole my awatar,and all this time i wondered where the hell it was,i want it back.
Thank you.
[quote="GhostDog"]Damn you,you stole my awatar,and all this time i wondered where the hell it was,i want it back.
Thank you.[/quote]
No, honestly, this is my old one, I just used brasso on the cog wheels and I trimmed the edges to make it more square, honest!!
This is a picture of my old one before I cleaned it.
It was hard work, had to use a toothbrush to get in between all the teeth, and hammer and chisel to get rid of those old bits of bricks. Took me hours to do it!!!
5 days without a single post in this thread!, must be a record 😮
I can't find any good avatars...Best make my own then :-?
[quote="IZZO"]I made it for Muffy's return, do you think he will like it?[/quote]
Most likely, yes. 😊 maybe wants one for himself, too 😃
[quote="JyriK"][quote="IZZO"]I made it for Muffy's return, do you think he will like it?[/quote]
Most likely, yes. 😊 maybe wants one for himself, too 😃[/quote]
That can be arranged 😉
But, isnt that a nice and confortable location to be in 😃 😉
Atleast to the time MBuffy gets back 😃 😃
Beginning to fear that day, so much posting... 😃 😮
Does anyone actually know when Muffster gets back?
I'm not racing with anyone for posts, I just spend so much time here it's hard not to get a high post count.
I think i'm posting around 20 post per day at the moment, which is more than usual, but it will level out at some point. 😉
[quote="Dazler"]I'll catch you when a new communicator comes out, or I get a 7650 😉[/quote]
Thing is the 7650 forum is crazy, I better go to bed befor I fall on the floor!
[quote="samthepaokfan"]Guess I should change mine too...
Lets organize a poll !!! Should Sam the Paok fan change his avatar ???
Filakia[/quote]
Whatever u do, pls keep the good ol sheep in u!!!
:robot: "May The Sheep be with you...."
