oplayo kern-exec 3 error
3 replies · 4,490 views · Started 11 November 2002
Is anybody getting this error when they trying installing the oplayo 7650
player in their machine (ok, handset)? This is after downloading and
transferring the installer app into the device.
I did a search for this prior to posting ... nothing came up. There is in fact
two of us that have this problem, so we'd both appreciate any help.
Cheers / todopulgares.
Well honestly i never encounterd this error. But i think i got the same thing when i was using the screen saver. But I think you should try uninstalling the app. And they installing it again. IF still presists, mabye something is screwed up when you downloaded it from the internet. download it again, and try it.
Hope this helps!
(i hate is when I post and nobody answers, thats why i think we should help everybody around here, or atleast, just not let them feel that they're left out!!) It happens to me in PPC forums, thats why i ditched them!
So the installer gives you KERN-EXEC 3? You probably have Installer v1.0, which is known to have problems like that.
What I suggest is that you go to Oplayo website and go to the download section. They should now have there either the full Oplayer 1.01 or Installer 2.0 available, either one of them would effectively solve your problem.
** Magic **
Have read many of the oplayo posts, I was of course hoping it would be
magic who cast his eye over my error. I had done what ) suggested
already thanks alot for the contrib anyway.
True enough, oplayo have changed things, and now you can download the
whole player. BUT ... I'm having connection problems now ...
That's a separate problem though, so consider this thread closed. Thanks,
both.
