9210i LOG problems
1 replies · 3,205 views · Started 20 September 2005
hallo!
as you all know, there is a LOG report which consist every activities that ever occured in the cell phone.
What i want to know is :
1. how can i print it without using IR? Because i don't have any IR'ed printer.
2. can i just normally extract it out from phone to PC? how? and then print it...
thanks...
ps: i use IR, not cable data to communicate between pc and phone
Right now the only way I know of is install extended printers from Psiloc. This allows you to print to a text file. This text file can then be transferred to a PC.
