Ringtone Studio v1.0
15 replies · 3,140 views · Started 12 November 2002
Wildpalm have just released Ringtone Studio so check it out here:
http://www.wildpalm.co.uk/rtone7650.html
Features:
Load any Midi song and save in a compressed format to save storage space
Change the instruments on any track of the song � choose from up to 128 instruments
Mute or change the volume of any track
Change the volume of the whole song � manually, or automatically set to maximum
Change the speed of the song
Automatically trim silence from the start of a song
Manually trim the start and end of a song
Send ringtones via MMS, IR, Bluetooth and Email
Full on-line help
Free Trial
wowwwww!!! I like this soft.... is the best for change your midi files... Volume, etc... incredibleeee!!!
including original NOKIA midis....
Thanks... 😃
Is there echo in here or what? 😃
What's interesting about this software is that it is supposed to send MIDI songs over MMS!!! This was not possible so far. In fact, in forum.nokia it is mentioned that it is not possible to send midi songs from one phone to another due to copyright issues etc etc...
Just tried it, and its a great app indeed. Much easier to edit midis than with my PC - one of the rare situations where Symbian is better than Windows 😊
Gonna buy it now.
... and bought it. Got the unlock code 5 seconds afterwards .. 😊 .. Sending midis by MMS or mail does not work - I think this is because of restrictions in the phone software - copy protectment ...
And do you know if there is any app for 7650 to convert midi files to arm files? Then we could send the files via MMS 😉
Dont know such an app ... but converting midi to arms would make them loose their polyphonic quality, am I right?
Could the sending be possible with changing the filename to
something else with some filemanager and then send it?
[quote="77877mgxf"]You cant save the edited midi.[/quote]
do you mean... trial version of Ringtone Studio will not expire? the user just can't save the edited midi?
thanks in advance 😊
[quote="Freddie666"]Hmm, thats a good idea ... I will try it after work 😊[/quote]
Did you try it? Did it work?
Hi guys,
I just installed the trial version of Ringtone studio but I can't figure out how to apply what I did 😞
This what I just did:
I opened 1 midi then I selected Edit and choose 200%
after this I dunno what to do next? 😞
can some guide me please...
thanks in advance
@ JyriK: yeah, I tried, but it didnt work ... 😞
@ daniatt: simply save the midi ...
