Using new mmc card - correct procedure?
1 replies · 1,530 views · Started 27 September 2005
I have searched the forums but cannot seem to find an appropriate answer.
My question is...
I have purchased a new rs-mmc card for my Nokia 6680, and want to copy ALL the contents from the bundled 64 Meg card to the new. Now, this would be straight forward if I could see the hidden folder structure on the bundled mmc card; eg System folder, which contains word, excel and other useful apps. I can copy everything else fine, eg Images, Sounds etc, it's just this System folder which is hidden from view in Windows Explorer and the Nokia PC Suite.
Any ideas?
Thanks in advance.
you need an usb card reader to copy the content of the card on your PC, don't forget to set show hidden files just in case.
copy the content of the old card on your pc and then copy the files back on your new card, and that's all.
