Hi all,
How is the sound in the N70 when it comes to the built in speaker?
And also, does anyone know if the email client supports SMTP authentication? Many thanks! Chris
How is the sound in N70?
Christian_1 wrote:Hi all,
The sound quality from the N70 is pretty good in my opinion. It is slightly better
than a Sony Ericsson W800i / K750i. Have compared them to the N70, both
through embededd headset, through built in phone-speaker, and through
cable over my Hi-Fi system. The embedded headset (HS-3) is actually pretty
good in my opinion. Still I have made my own cable to be able to use
my KOSS headset which is slightly better (more bass)..
The sound quality is also better than my previous Sendo X.
Have also compared to mu Creative Muvox MP3 and my Sony M-7 MP3 player, and
the quality is just as good, and just as loud.
SMTP authentication I do not know yet. Only thing I know is that when I use
ProfiMail 2.32 there is an option of "Secure SMTP" usage, and this seem to
work, so I guess then the N70 supports SMTP authentication. Will look further
into this.
Sounds is fine IMO. No SMTP auth.
Hi
i am in need to know about the sound quality of N70 with headset HS-3.
How do you rate the N70's sound quality
Bad...:icon13:
Average...🙄
Good...:icon14:
Very good....😎
Awesome.... 😃
Thanks ...................
