Original operator logo
5 replies · 3,722 views · Started 14 November 2002
Go to the Oplogo folder you created and delete the images or name them to something other than 234_15_0.bmp (Vodafone UK).
Is the operator logo stored on the phone or the sim card?
I have 3 sim cards to different operators and I've assigned their company logo to each one. When I put the sim card in, it never changes from what I set it to and so forth with the other sims.
Also, what happens when sTools trial runs out? Does your operator logos go back to as was?
[quote="MR-6T9R"]Is the operator logo stored on the phone or the sim card?
Also, what happens when sTools trial runs out? Does your operator logos go back to as was?[/quote]
I dont think it will go back to the previous logo. What sTools did is just to rename the operator logo that you have selected to your operator's id and put it in the oplogo directory. I dont think that it will delete this bmp when the trial expires 😊
[quote="alvinpaul"][quote="MR-6T9R"]Is the operator logo stored on the phone or the sim card?
I dont think it will go back to the previous logo. What sTools did is just to rename the operator logo that you have selected to your operator's id and put it in the oplogo directory. I dont think that it will delete this bmp when the trial expires 😊[/quote]
AWESOME!!!! 😃
[quote="MR-6T9R"][quote="alvinpaul"][quote="MR-6T9R"]Is the operator logo stored on the phone or the sim card?
operator logo is stored in the phone and not the sim.
AWESOME!!!! 😃[/quote]
