Anyone tried the RMR Art 4 for 9210. After installing, I try to run the program but it comes back with
Note
BMP.OPX
OPX does not exist
Any idea what's wrong?
Note
BMP.OPX
OPX does not exist
😃 Hmmm... I think your OPL files is not complete. Try reinstalling OPL Runtimes. After u reinstall the latest version, check if BMP.OPX is installed inside the OPX folder (system--->OPX)...
Quite a few people have been having the same problem. The answer is indeed to make sure you are using the latest version of the OPL runtimes, and that the BMP OPX is installed.
Andy
complete bullshit as bmp.opx isnt included in the latest opl runtime. neither it is in rmrart.sis. a good example of why i better should forget opl on er6 and above
:-? log in as a registered user and u shall see the BMPOPX installer above...
