SkinStudio v1.0 for Nokia 9300/9500 is now officially released. SkinStudio allows you to create, modify and install skins on your Communicator without rebooting.
SkinStudio can be downloaded from the downloads page at http://opldev.broeze.com.
Since I will be on Christmas vacation during the next two weeks, I won't be able to read the forums. If you have any questions or problems, please send me an email at arjen at allaboutsymbian dot com.
Happy holidays.
Best regards
Arjen
Update for iDesk users: if you had the beta version of SkinStudio installed and you upgrade to the 1.0 version, iDesk may stop working.
The way to get iDesk working again is to find the \System\Apps\SkinStudio\Modules folder and copy (don't move them otherwise SkinStudio stops working) all the files in this folder to the folder \System\OPM.
If you cannot get this to work, an alternative that gets iDesk up and running again is a reinstall.
My apologies for the inconvenience this may cause you.
Excellant ...it just gets better & better
Keep up the good job...i wish i knew OPL & i loved to ave lend a hand
hi really it work in 9500/9300 ?
r u sure ?😮
did u tried it ?
reply me
