128 mmc
5 replies · 1,944 views · Started 19 November 2002
I would like to know what are the best brands that produce the 128 mb mmc for nokia 9210/9210i. Where can I find it? Computer shops sell them? I tryed in some cell phone shops,but did not find it!
i'm currently using a 128MB MMC from PRETEC (Hitachi)...
so far it's working fine... have been using for 3 months already...
checkout:
http://www.valueflash.co.uk/Multimedia_card.htm
p/s: i bought mine at the local computer/pda shop... It's cheaper than getting from the net sometimes... 😉
Thanks 😃 ,I,ll try in a computer shop. Will I find everything I need to set up the mmc on the nokia site? You know...all the applications and things like that...
the fastest/easiest way is to copy/backup everything from your old MMC to your PC then copy it back to the new one... 😉
I found the shop that sells the mmc that I am looking for! I didn't buy it because I didn't know what brands were better...any suggestions? before purchasing one,should I know something else?
To my opinion, the best brand should be the one which can offer longer period of warranty... mine only offered 1 year warranty... there are some brand that offer more... for instance, KODAK offered 5 years of warranty!!! 😉
