New wav for ringtone
34 replies · 5,779 views · Started 19 November 2002
I have made this one and it sounds great @ my 9210 😊 If you like jazz you`ll love it ...
Damn, how to attach a file on this post??? I go on Add an Attachment and browse, pick up that file and press attach and nothing happens 😞
You must not exceed the maximum size for attachements (200K will be enough for dial up surfers)
Also try to put it as zip file.
It is converted by Multimedia Converter, maybe there is some noise because it is live recording but I love it anyway...
How do you upload a ring tone like the one above?
:roll: :roll:
I've got a very loud F1 ring tone which makes the 9210i vibrate a little, its that loud and AWESOME- F1 Car accelerating 😃 😃
8) All u have to do is just zip it and add as attachment to your posting... and yeah, size does matter... keep it small...
[quote="Nosferatu"]8) All u have to do is just zip it and add as attachment to your posting... and yeah, size does matter... keep it small...[/quote]
Mines very large, the ring tone that is, 😃 😃 its about 340kb, is that small enough? :roll: :roll:
U can try but i doubt it u'll succeed... did u already convert it with multimedia converter??? it cant be that huge... 😮
No I recorded it from a video 😃 😃 , i'ii convert it with mm pro if it reduces the size 😊 , but then the quality will be reduced also :cry: , something which will spoil :cry: :cry: the sound of this very powerful F1 ringtone.
[quote="4u2nv"][quote="Nosferatu"]8) All u have to do is just zip it and add as attachment to your posting... and yeah, size does matter... keep it small...[/quote]
Mines very large, the ring tone that is, 😃 😃 its about 340kb, is that small enough? :roll: :roll:[/quote]
Send it to me and I'll add it to the WAV section of my site....
[quote="N9210"][quote="4u2nv"][quote="Nosferatu"]8) All u have to do is just zip it and add as attachment to your posting... and yeah, size does matter... keep it small...[/quote]
Send it to me and I'll add it to the WAV section of my site....[/quote]
I should of thought of that, anyway its on its way soon. 😉
😃 Hmmm... i think it'll reduced to somewhere below 100K... don't use high compression for the sound... use the one for music compression... anyway, the sound will becomes MONO...
Hello, Patrick (N9210).
Do tell us once you have posted the F1 wav file on your site. Thanks. :angel:
[quote="apcaw"]Hello, Patrick (N9210).
Do tell us once you have posted the F1 wav file on your site. Thanks. :angel:[/quote]
Thank you Patrick, Please inform us.
well.. lets start all over again... so ppl.. pls submit some nice wavs for ringtones here... i would prefer musical wav actually... 😉
8) Here's the famous "The Saint" theme...
was really famous while ago when the movie spotted the first communicator... cool movie too...
[quote="n9k"]This one is from me! hope it OK, Dub from 7650 and 7210.. :lol!:[/quote]
Way out cool! :P
Why didn't anyone thought of that? Using a wav file of a polyphonic tone. In my country, polyphonic tones are the hottest craze. I usually boast about the 9210's capabilities of playing the actual song, but since the speakers are mono, it just sounds I have an old monotone transistor radio.
How were you able to get the wav file of a polyphonic tone? You recorded it thru the recorder? Or did you just downloaded it from the net.
I hope I can get more of these wav files.
Thanks. :angel:
Thanks apcaw, In fact I just dub it through a recorder. 😃 In addition, here is another two I've been using for quite a while. Hope it OK!
Wow! More polyphonic tones (wavs actually). Cool. 😃
So you get a 7650, play a tone and record it? Lucky you for having access to a phone w/ polyphonic tones. None of my friends have one that I can borrow and play around with. :evil:
Please post any new wavs (polyphonic) when you get one. Thanks.
WOW i've just been playing those rings from tones pack 3 and they are sensational the PPK and Syvester, truly rocking tunes these 2.
Can you mix them together?
This would be useful, well i just want to show off to all thos epeople who think there smart arses with polytonic whatever you call them ring tones! 😉
MORE MORE MOOOOORE ring tones pleeeeeeeeeeeeeeeeeeeeease! 😉 😉 😃 😃 😃 😃 😃 😃
thanks for the great tones guys.
Here is a tone for arabic music lovers.
Sounds like ringing Billy Dance.
You must not exceed 250 Kbps.
Try to use ad an attachment, then brouse for the attachement and then submit.
As a registered user you will be able to delete or edit your post. See in the up-right corner of your post.
Edit==>Add==>>Submit.
An welcome on AAS as registered user.
More to come.........
