Black key pad
15 replies · 4,384 views · Started 30 January 2006
Just got a all black case for my N70 looks great but a black key pad would finsh it off prefebly with chrome on the joy stick any one know where I can ges one
Info on that has been posted on this site.I must admit I just played with it till it came apart quite straight forword when you have new covers in your hand
how about the quality ? is is good ? one mor thing... how can you remove the backcover at the camera ???
the cover is better quality than the original one on the phone but it is still a genuine nokia cover. To remove the camera cover take of battery cover then on the bottom of camera cover tweek out the sides and then slide up over the camera, as I say when you have the new covers in your hands all becomes apparant
it is indeed cool, about a tutorial, I saw a thread with pictures here on this forum, just have a look around.
A black N70 is really unique. But I don't risk it to open up my phone for an other cover unless the cover is not so good anymore.
I got one of the black cases and black keypad, but at the time I�ve installed on the phone I realized that the sounds of pressing keys at the keypad was lower than normal (I do not know the cause of it), I put off the black cover and keypad and re-installed the original and sound were back to normal. It�s weird this thing (of course the case and keypad was not NOKIA original)
I have ordered 2 different black covers from ebay to my Nokia N70.
The material of the cover is rubber-like, and very good quality.
The black keypad looks nice, however, sadly is very hard to use.
I think it is a little to thick, which makes it really hard to press and
use it, especially the navigation pad.
I also tried to combine, with silver fram and black keypad, did not
look as nice as I thought, and also the keypad is so hard to use
that I am gonna remove it..
Anyway, take a look..
Attachments: 1.jpg 2.jpg 3.jpg
messus wrote:I have ordered 2 different black covers from ebay to my Nokia N70.
I also bought the Black Rubber-like case & keyboard. I agree the keypad is not a good as the original Nokia but it looks very cool and you eventually get used to the firm keypresses required.
However, the back cover of the case does not work for me. It is missing a plastic leaver which activates the 2MP Camera when the slider is opened. Without this the camera cannot be activated. Do you have this problem?
The Ebay seller is ignoring my requests for a replacememt, so I am stuck using the original (silver) Nokia back cover with the Black Rubber front & keypad. It's a shame, as the black rubber cover is otherwise excellent.
Cheers,
Dez
dez_borders wrote:Hi,
Cheers,
Dez
I have ordered two black "rubber" covers, and one regular black plastic
covers for my N70, all of them are working fine with regards to enabling/
disabling the camera with the slider. One of them had a slight mailfunction
with the memory card protection/opener, but I managed to fix this.
I gues you were a little unlucky!
Yep, I have the rubberised N70 cover from eBay (Hong Kong seller if I remember correctly) the slide works fine for me, enables the camera as it should.
The build quality isn't quite as good as the original covers but the N70 looks fscking good in black! Now if only I could get a slider-less back cover...
SebBelcher wrote:Yep, I have the rubberised N70 cover from eBay (Hong Kong seller if I remember correctly) the slide works fine for me, enables the camera as it should.
Agree, a back cover without the slider would be nice, and just with a lense
protections system like e.g on the SE K750i..
Thanks for the feedback. To be fair to the Hong Kong ebay seller, they did eventually supply a replacement back cover, and the camera now works OK.
The 'Black Rubber' case & keypad looks very cool, and works fine for me now.
Dez
I bought a black case for my n70 from mobilefun,after taking the silver one off and putting the black one on i prefered it in silver,itr looks more classy in my opinion,also the on/off button would'nt work
