What is the catalogs program? What is it for? Hope someone can tell me. It comes with the phone, on the memory card.
Catalogs?
itsa a quicker way to buy software.you buy it over the air & i think it comes directly from your credit/account balance no creedit cards needed.but cant tell you to much since only started it up once & then got rid of it.
Ah... Thanks for the reply. I will probably do the same as you, get rid of the program. I have no use for it. 😊
its downloadable again if you want it(nokia website>support>n70 support>phone soft>general soft)
