Hi all,
Might buy this phone this week but have a question!
From what I understand it is possible to record audio form external sources, like the home stereo or whatever. Isn't this correct? If so, does the headphone jack also work as a line in input?
Many thanks!
Recording from external sources on the N91?
In theory there is a cable CA-63U that does something like this and yes it plugs into the headphone jack. However I haven't seen anything about this since the launch.
Rafe wrote:In theory there is a cable CA-63U that does something like this and yes it plugs into the headphone jack. However I haven't seen anything about this since the launch.
Ah, yes as I thought. Can the phone then record this into .MP3 or whatever?
The cable you talk about this is not included in the package?
I'm afraid I don't know. I think it is possible that its a funtionality that is no longer included sine I don't think it is mentioned anywhere (e.g. in the manual).
The cable is defintely not in the sales package.
OK, well I read it on their webpage that you could record from other sources so I really hope that it will work
I had a look in the manual but couldn't find anything about recording from an external source.
[QUOTE="Nokia"]Sales Package Contents:
Nokia N91
Nokia Music Headset HS-28 (with remote control)
Nokia Stereo Audio Cable (CA-63U)
Nokia Battery BL-5C
Nokia Travel Charger AC-4
Nokia Connectivity Cable (USB) DKE-2
Nokia Charger Adapter Cable CA-44
Nokia Desk Stand DT-10
CD-ROM containing software (PC Suite and other applications)
User guide, Quick Start guide, and Add-on Application guide [/QUOTE]
it does have the cable😊
