Hi guys! I was wondering if there was a way to use the MMC as the storage for sms messages... i tried copying the Mail folder and re-pasting it but it did not work... I even tried Other apps to send a compiled msg to the PC but it sucks cause the program just crams up all the txt and its hard to arrange and read it...
is there a solution for this? or is there a better app than that Msg storer thing...
Need Help Guys! Thanks in advance!
Install MSdriveE.sis. After that, all messages go to MMC. The messages who may be in archive in the device, stay there, but you can�t see them. Remove the card, and reboot the device, and the things keep the initial ones.
MsvDriveE.sis (1 KB)
Uhmm i have problems regarding this software... are there other alternatives? is there a better software for the ngage?
and is there a better hard format except the *#7370# i need a better one. something like the one on the 6600 where you hold buttons.
Thanks in advance!
No alternative sw for that & no better formatting tricks either for the N-Gage. A Nokia repair center can reflash it, though: http://www.nokia.com/repair
