copying the contacts db
4 replies · 1,312 views · Started 10 May 2006
Hi, for tests purpose I need to copy the n70 contacts db file available in "c:\system\data\Contacts.cdb" and all I've tried so far fails.
using fexplorer to copy it to the memory card or somewhere else, using bluetoot transfer...
Is there any way to get this damn db out of the phone to the pc?
Thanks a lot.
Normally the contacts.cdb cannot be copied since it is in use all the time.
The only way that works that I know is to make a backup (using the built-in backup application) to the MMC card and then copy the file from the backup to the PC.
Thx for your fast answer.
However, I can't find such an app on the n70. What is the exact name?
The closer is transfer, that does bluetooth transfers but fails to pair with my pc (with which the n70 is already paired and working properly both for bluetooth transfers and syncs.
thx again
some progress, I've found the app that is part of the memory card management app.
I now have a nice backup.arc file I don't know how to uncompress (tried winrar).
What's the next step?
UPDATE: In a slightly different approach, is it possible to sync the simulator with pc suite, which would create the file I'm looking for 😉
