How to disable flashing blue light when in sleep mode..
38 replies · 52,512 views · Started 22 May 2006
tomnufc wrote:I think Nokia should make more use of the LED to be honest, maybe have it on when a Bluetooth connection is established, that would be cool
My last phone (Windows Mobile 5 :frown😊 had 2 multi-coloured leds, 1 for battery related and network signal information, the other for information re WiFi, Bluetooth, messages etc. I found them really handy but I doubt if the people who are unhappy with the N80 led flashing at night would be thrilled 😃
Mistoffelees wrote:If you use Taskman you can see this application called blinkingled
in the Applications list.
Maybe if you try to terminate that your LED stops blinking.
I'd rather not try it out myself, have no experience with stopping
system processes in SymbianOS but it sounds kinda logical.
I tried this but the Taskman tool does not terminate the application .. so nothing there ... 😡
/Jan
knuckleskin wrote:I agree tomnufc if someone developed a replacement program you could get it, for example, to flash more frequently when you have a text message or missed call. And to not flash at all if a certain profile is activated, unfortunatly i'm not prepared to learn Java EE this summer.
but it will drain the battery 😞
x-daemon wrote:just turn your n80's face down. so, you won't be seeing the blue light.
:tongue:
Not seeing the blue light doesn't stop it flashing and draining the battery...
Hi, I'm not sure if my phones the same as you guys but mine did that annoying flashing blue light thing on sleep mode as well until:
I went to profiles, personalise, light indicator.... and switched off.
:tongue:
That's what I always do, or i'll put it under my pillow(That's really bad for our health).
Maybe the blue light is designed for the ppl who look for his phone at night lol.
dez_borders wrote:Not seeing the blue light doesn't stop it flashing and draining the battery...
Far less of a drain than everything else on the phone, and certainly far less than having the screen powered and a screensaver running (see my comment below about that). The software to run the light will make virtually no difference to the power consumed compared to the power taken to run the OS. The blink of the LED every few seconds will take next to nothing in power either.
abc2390986 wrote:Maybe the blue light is designed for the ppl who look for his phone at night lol.
It's simply designed to indicate the phone is on, as to save power amongst other things, the screen is completely powered off when not in use. The idea is to provide an indicator to show it is switched on, as a traditional screensaver can't be used.
With OLED displays this will be even more important as the displays have a short life span and must be powered off whenever possible.
I agree. killing this big huge oversized led would save a lot of battery. perhaps not requiring to recharge ..ever . again 😃 looool
Fear not, simple fix. take the cover of and very carefully position a smal screwdriver, like a torx6 over the led. and then ..very very extremely gently "position" the... aham... hammer 😊))))
