Is there anyway to lock the phone keypad without opening and closing the slider?
Lock keypad without slide?
HI the power button, then select lock keypad
Not ideal though, takes longer than the slider!
I wish there was a double key press sort of thing or at least an auto lock keypad after x seconds option.
Yeah me too, reckon someone will write one in due course.
I hate the request *every* time I close the slide asking whether I want to lock the keypad or not. I detest it so much.
The N70 uses a quick double key combination...
'Left Soft Key' + '*'
Is the N80 the same? Much quicker than the power button then select from list option.
S.
No, this is not an option on the N80.
LesLesleyson wrote:No, this is not an option on the N80.Ahh mistake. :redface:
S.
wireplay wrote:HI the power button, then select lock keypadNot ideal though, takes longer than the slider!
Just found this lock program, now I can lock the phone straight away with the press of one button 😊, I have assigned the lock button to my right soft key because I dont really use that key too often, I also have the auto lock function enabled in case I forget to press the lock button
Cash wrote:Just found this lock program, now I can lock the phone straight away with the press of one button 😊, I have assigned the lock button to my right soft key because I dont really use that key too often, I also have the auto lock function enabled in case I forget to press the lock button
That's a really useful program, good find cheers!
Jay3gsm wrote:I hate the request *every* time I close the slide asking whether I want to lock the keypad or not. I detest it so much.
I really agree. That's so damn annoying. I'd like the locking behaviour to be like this :
- lock when closing the slide and unlock when opening
- auto lock after xx seconds or mins or whatever
I don't know to what extent the N80 is customizable, but do you see it as possible ?
There's so much to tune...
Gurney wrote:I really agree. That's so damn annoying. I'd like the locking behaviour to be like this :- lock when closing the slide and unlock when opening
- auto lock after xx seconds or mins or whateverI don't know to what extent the N80 is customizable, but do you see it as possible ?
that would b really usefull
A couple of other options:
Rather than pushing power quickly, then down, and then center to lock the keypad, you can push power quickly to bring up the list, press power quickly again to go to the next item in the list, and then hold power to select that item. It's still a few keypresses, but it's at least the same key.
Or another third-party solution... both HandyClock and HandyWeather come with screensavers.... the Weather one is amazing (show's you every possible status in addition to todays and tomorrows' weather). Anyway, you can set in the preferences of either application when to auto-lock the keypad if you have their screensaver assigned.
I already love the HandyWeather app, and when you add the auto-keylock it increases the value even further.
Cool thanks for the info i must try this
