GIF specs that 7650 can play
11 replies · 3,627 views · Started 26 November 2002
just wondering wat fps of an animated gif can a 7650 play, coz i got here a lot of animated gif's , some animate some dont, i checked it at my pc and all of them animate.
The 7650 can play any kind of GIF, but they only loop once when you open the GIF to view as a regular image. but you can use the latest version of SeleQ to view GIF files, it's much much better. And also the screen saver applictaion from Psiloc.
It takes a while to load, depending on your GIF size, so be patient!
can u test and see if this gif animates just using the built in image viewer??
coz i cant seem to get it to the gif to animate, i dont have the screensaver and seleq 😞
no it does'nt get viewed on my phone. The regular image doesn't always play all GIFs, alot of times it doesn't.
Anywayz, you can try SeleQ, download their trial.
SeleQ is an excellent app, but you can also view animations with AniViewer, a tiny freeware program.
i think the most important thing to consider when it comes to viewing gifs with the screen saver is the weight of the file (size). the lower the size the bigger possibilty it can play with the 7650.
[quote="paloyme"]can u test and see if this gif animates just using the built in image viewer??
coz i cant seem to get it to the gif to animate, i dont have the screensaver and seleq 😞[/quote]
man where did you get that GIF 😊
[quote="FOX HOUND"][quote="paloyme"]can u test and see if this gif animates just using the built in image viewer??
man where did you get that GIF 😊[/quote]
i also have that. i think what i have is actually bigger. i tried with the ssaver before it never worked!!! - and yes this gif is freaking hilarious!!! 😃
well the ur seeing on the post right now, is the edited one, i kinda shortened it and lowered the fps, but still it wont play, oh well, i guess back to the drawing board
