N80 Sliding function (Close phone without hanging up?)
8 replies · 4,811 views · Started 02 June 2006
When I'm on a call, how do I close the phone (slide the phone down) so i can make the phone smaller WITHOUT hanging up on the person i'm talking to??
please help this is quite annoying.
thanks
Curiously mine (bought sim-free) doesn't hangup the active call if I close the slider. I just get the usual "Lock Keypad" prompt but the call stays active.
AFAIK I haven't changed anything in the phone config to have it this way - unless it's related to the anykey answer option (which I have switched off).
HTH
ants337 wrote:When I'm on a call, how do I close the phone (slide the phone down) so i can make the phone smaller WITHOUT hanging up on the person i'm talking to??
thanks
When in call, press the menu button then close the slide.
When you Make a Call Just after Making the call close the silde, i will not cut the call but if the cal is been acepted i.e. the call duration has been started then you close the slide it will hang up the Call.
I think if you hold down the left selection key during the call as you close the slider should work. It used to be like that on the Nokia 7650
thanks
As soon as you dial the number close the keypad and the phone will keep ringing.
STu
i want the other thing,
my n80 doesnt hang up when i close the slider, but i WANT IT TO
is there anything i can do so that the phone hangs up when i close the slider ??
