Hi everybody!Would you please help me out...? My 9210i is getting slower,I don't know why :-? ! Do you suggest a nice format and,when installing back I put EVERYTHING in d: rom? I have switcher, but still with almost every app killed my 9210i results at times really slow :evil: !!! Especially in the message and agenda apps! Do you think it's slow in message and agenda becase I created the databases in the mmc instead of using the normal c: rom space? Thanks so much....The Godfather.
Please advise me
the mmc is always slower then the c drive. A nice fresh install will help. But don't bother to install everything to the mmc. Install only the important once on c and then the rest on the mmc.
😃 Do u surf and check emails with your 9210 a lot??? If yes, u should just try deleting your temporary file... rather than formatting your 9210...
To remove all temporary files just follow this easy step:
1. Restart the communicator.
2. When you see the Nokia 9210i Communicator Welcome screen, immediately press and hold down the Ctrl+ Shift+ I keys.
😉 This will delete the Temporary files. This empties the cache, removes cookies, resets plugin registrations and resets the settings you have made in some of the applications including all Internet and profile settings, Desk shortcuts and display settings...
Just a question: I did this operation. There isn't any confirm message that I did this operation?
It is also a vehiculated Ideea of cleaning your log file.... May be it will work
[quote="The Godfather"]Just a question: I did this operation. There isn't any confirm message that I did this operation?[/quote]
If done correctly, u will get a white splash screen:
"About to delete all INI files. Are you sure?"
😉 then u can decide to "delete" or "cancel"...
Thanks...I'll do this and see if it improves. But if it doesn't,do you suggest a format?
It's your LAST RESORT i guess... before the FINAL SOLUTION...
Formatting... hehehe... 😉
I'll let you know in a few days :-? !!! robably if i'll have to format, I will ask for some help... 😮ops: ...thanks 😃
[quote="Nosferatu"]😃 Do u surf and check emails with your 9210 a lot??? If yes, u should just try deleting your temporary file... rather than formatting your 9210...
😉 This will delete the Temporary files. This empties the cache, removes cookies, resets plugin registrations and resets the settings you have made in some of the applications including all Internet and profile settings, Desk shortcuts and display settings...[/quote]
YOU a 100% master of 9210 TECHNICAL informatioin
[quote="The Godfather"]I'll let you know in a few days :-? !!! probably if i'll have to format, I will ask for some help... 😮ops: ...thanks 😃[/quote]
Here I am again...
I've deleted the ini files,and actually the phone improved and got faster...but I'm noticing that every day that passes my space in c :rom is getting smaller. There is something eating up space on my c: rom and I don't know what the hell it is!!! :evil:
I don't have extra software installed in c:rom and my call log lasts for 5 days... :-?
HELP...
Have you installes smart memmory, task manager, switcher(free) or AppManager (Most Recommended)?
Each time you open, telephone, office, internet, extra and other apps, they remain active=>wich results in RAM Consumption.
Try to install one of the specified task managers and see for yourself how things will change.
SmartM
http://www.allaboutsymbian.com/software/directory/viewsoft.php?id=125
TaskM
http://www.allaboutsymbian.com/software/directory/viewsoft.php?id=185
Util
http://www.allaboutsymbian.com/software/directory/viewcat.php?c=Utilities&d=Nokia%2092x0
Hi Godfather,
😃 glad to hear that it actually speed up your 9210!!! easy huh??? anyway, regarding the space thingy are u referring to c drive??? how bout let us know what apps u actually installed???
p/s: 😉 check your messaging too... undeleted infrared items also reduced space... and check your message storage settings...
Yeah...seems it's working... 😉 ...THANKS 😃
Yes,i'm refering to c:rom.
On my c:rom I have: word,exel,and the ppt app and obviously file manager.
Imaging,conrtol pannel,realone player,date/time,internet settings,data mover,video player,modem/fax,cell broadcast,calculater,recorder and guide.
You think I should move them to d:rom?
I understood that z:rom is the ram...?I've never fooled around with z...
[quote="The Godfather"]Yeah...seems it's working... 😉 ...THANKS 😃
I understood that z:rom is the ram...?I've never fooled around with z...[/quote]
RAM (Random Access Memory) 😊 ==> 8 MB
ROM (Read Only Memory) 😊 ==> Z drive
Storage ==> C: & D: 😊
:angel: :angel:
