TDK have announced their first Bluetooth hard drive. Just as we all starting shouting "woop-de-doo", we saw how much it's going to cost - $400 for a 5GB HDD? Are they MAD? So, I thought of another option. I'm putting this idea down in the hope that someone with the right facilities reads it and thinks "hey, what a cool idea, i'm going to build this". I don't expect royalties if you use the idea, but some recognition would be nice!
Here's my idea - forgive me if it's not explained very well, but you should get the idea!
Imagine a standard hard drive - they all look pretty much the same. You have a rectangular piece of metal which contains the platters, and at one end you have the socket to plug in the IDE cable, and a socket leading to the power supply. Everyone with me so far? Good. If you're not, look at <a href="http://www.acmehowto.com/howto/pc/images/harddisk.jpg"> this</a>.
Now, what I'm thinking of can be described in it's simplest form as a condom for the Hard drive - but instead of providing contraception, it provides Bluetooth! Imagine a device that is the same width and depth of the hard drive, but only about an inche long. This device would fit on top of both the IDE pins and the power supply pins.
So, can everyone imagine this so far? We've got a hard drive with a little plastic gimmick on top. Now sit back, relax, and see where the bluetooth comes in...
Inside this little device is a BT sender/receiver, with a range of about 5 meters. This device is just intelligent enough to know the formatting of a hard drive - it knows only very few commands, enough to query the data on the drive, get files, see file structure etc. It can also read and write files. When this device is clipped on to the top of the hard drive, it fits on top of the IDE pins - this means it can query the hard drive in the same way that a PC would. The power pins would lead to a battery, which provides the power for the unit (it can also be mains powered).
The drivers for this device would also be relatively simple - they would simple need to send the exact same data that an IDE controller would send to perform the current operation (delete file, save file etc), but instead of sending it to an IDE device, send it via Bluetooth. My device would then take your request, query the hard drive, and send back information in the same way a standard IDE controller would.
Technically, I believe this idea is a good one (although I say it myself!). The only limitation I can see is Bluetooth transfer speeds - but they will eventually improve. This device would essentially make any hard drive Bluetooth compatible, just by clicking in this device. Imagine... you go and buy an 80GB hard drive for about �120, stick this device on the top of it, and BAM, it's BT enabled. Copy all of your mp3s accross on to it, then put it in your bag. Who said a 7650 wouldn't make a good MP3 player!
Something else that I would probably recommend to anyone making this would be to have a cover to put on the whole hard drive, as they are quite fragile little things!
So, what does everyone think? I mean, yeah it would be useful from a 7650 point of view, but imagine the possibilities... you could put a Hard drive in your bag, take it to work, copy some mp3s on it from your fast work network, then take them straight back home. Now that is truly the definition of transportable data!
I posted this in the misc forum yesterday, but I figured it would get a better audience and be slightly more relevant here.
