Hi folks,
I'm about to go searching for a service centre, but I thought I'd pass on what's been happening with my N9500.
I got my N9500 2nd hand from a pawn shop in the box with all the manuals, cable, charger & accessories. It still even had photos that the previous owner had!
Anyway, that was nearly 12 months ago & everything has been working fine, until now...
Apart from the fact that I run Win98SE (read: no Nokia PC Suite), I've been doing weekly contact backups to the MMC.
I can't be certain, but I installed some <cough!> archival software (anyone know ASA2005?) called camcorder. Upon install, the system told me that it wasn't 9500 compatable software & would I like to install anyway. So, I did...
Well, the software didn't seem to work (error: Could not find target), so I tried uninstalling it, but the uninstaller crashes. I figured, "Let's do a cold reboot". So I took out the battery, waited, then re-inserted it & slid the back cover back on.
Next thing the Communicator boots up with the Nokia screen & the hands. I close the lid & try to boot the phone. The front screen goes white (for a minute or so) & then switches off.
So I leave the phone on charge (the battery was low - I think it may be on the way out, as it only lasts a day when on 2-3 bars) & left the communicator open. It was then I noticed that the hands would disappear as-if doing a reboot. Sure enough, the Nokia screen would appear, then the two hands.
I had a similar problem with my previous N9210, but when that happened, it was only the communicator that wouldn't boot. The phone still worked, albeit at a reduced functionality.
Anyway, as I said I'm going to take it to a service centre (if one is open today - public holiday in Sydney.au) & I'll keep you informed of the outcome.
Has anyone experienced this? I've searched back on the list a few pages, but I can't find anything that describes this fault.
Cheers.
- Mi.
