Disabled voice command - How?
4 replies · 4,856 views · Started 13 June 2006
Hi - Please help. I want to disable the voice commanding in Nokia N80.
I put the phone in my pocket and it accidently call international numbers in my contact. Is there a way to disable it?
Thank you for your help in advance.
-Notre
cah1982 wrote:try under the profiles options
Hi there,
Can't find any option under profile.
I left the phone in my bag with headset attached and keypad locked. unfortunately, the button on the headset pressed against the bag and it started dialing and dialing and dialing (both local and internaitonal) the whole nite..........
My interim solution is to turn on the autolock period (tool\settings\security\phone & sim\autolock period)
but to unlock the phone, one needs to enter the 5 digits security code.....
thanks!!!
From the manual, try opening Voice.cm application profiles and have a play with that.
that's all I can find at the moment
The_Poet wrote:From the manual, try opening Voice.cm application profiles and have a play with that.
Yeah, been there done that.....nothing to disable voice comm :frown:
thanks anyway!!!
