Where do I find the adobe reader for the Nokia E61 on adobe website ?
PDF reader for Nokia E61
You can download it here:
http://www.nokia-asia.com/nokia/0,,91844,00.html
thanks a lot Rafe !
By the way, I'm looking for a better email app then the one by default on the E61 do you have one to suggest me ?
Its highly suggestible to try out ProfiMail, Profimail is one of the best applications for S60 phone, it�s the great example how the s60 application should looks like. Its really the best application ever wrote for s60 platform IMPO, LCG authors completely ignored the Nokia User Interface Guidelines and brings completely new redesigned and user-friendly interface far away form traditional series 60 application. PM brings new dimension in boring s60 applications world, nice and small anti-aliased fonts, popup windows, progress bars and animations, just wonderful :icon14:
Hope that helps..
Have a nice and long wekend,
Apoc
Apocalypso wrote:Its highly suggestible to try out ProfiMail, Profimail is one of the best applications for S60 phone, it�s the great example how the s60 application should looks like. Its really the best application ever wrote for s60 platform IMPO, LCG authors completely ignored the Nokia User Interface Guidelines and brings completely new redesigned and user-friendly interface far away form traditional series 60 application. PM brings new dimension in boring s60 applications world, nice and small anti-aliased fonts, popup windows, progress bars and animations, just wonderful :icon14:Hope that helps..
Apoc
For OS 9, I thing, is the only one!
nader_ch wrote:thanks a lot Rafe !By the way, I'm looking for a better email app then the one by default on the E61 do you have one to suggest me ?
You might be interested in my reader Pdf+ (for S60 3rd edition Smartphones). It is available at www.mBrainSoftware.com/S60_3rd/Pdf/Pdf.htm
Sander van der Wal
Thanks for your info Sander, I'll take a look too.
nader_ch, I usually bypass the .pdf reading on my E61 altogether because of the awkwardness of screen size and having to toggle to and fro to read a line. Don't know if Sander's reader fixes this, but I use mobireader and convert pdf's into the native format, then read. It's brilliant, you get large fonts, use the screen properly, and even, if you want, autoscroll text.
The program is free. Find it at mobipocket.com
also see Using_ebooks_on_Symbian_S60_3rd_Edition_smartphones but note that this article doesn't acknowledge the ability of the mobipocket software to import .pdf & convert to native format.
Here some direct links to Symbian free PDF reader
Hello all.
I'd have to agree with Sander. I use the PDF+ program
and it works like a charm. The reader found on Nokia's
website, is totally worthless. Why? Well, if you try to
open a pdf larger than 1,5-2Mb, it just tells you that
"out of memory" or similar. Just my nickle & a half...
