FM Transmitters for N80 - is there one?
5 replies · 2,705 views · Started 14 June 2006
Hello Everyone -
I want to transmit songs that I am currently playing on my Nokia N80 into the FM frequency in the car radio? I am looking for something like the Griffin iTrip for Ipod.
Thank you for your response.
-Notre
Using the 3.5mm jack adaptor that comes with the N80, you can use any standard FM Transmittor.. (not iTrips though..)
http://froogle.google.co.uk/froogle?btnG=Search+Froogle&q=fm+transmitter
Any will be fine, but most need batterys unless its one that plugs into cigerette lighter...
Its better to have a stereo with AUX IN, then you just have 1 cable coming from under the dash that plugs straight into the N80 adapter... Sounds much better and easier than FM Radio method
nostarwhere99 wrote:Hello Everyone -
-Notre
Got this one the other day...
http://www.aqsound.com/store/en/view_product/x/198/
It works fine - sound quality is not bad but of course well short of what you would get with the Aux-In option that was mentioned
