i accidently removed with the control panel unistall aplication the autoexec daemon and kwnow the proggrams that started automaticaly upod reboot dont start!is there a way to install the autoexec daemon again???can anyone send me the sis file?
please help!!!!!!!!!!!!!!!!
This app will be installed when you reinstall any of the programs that use it. So ... jsut get the sis of one of those apps and re-install that one 😉
well for me the smart memotry program used it!dou oyu mean if i install it agiain it will work?isnt a sysmtem file?????????
😉 Yup, u just need to re-install Smart Memory...
