Diashow is an application for your Nokia 9300(i)/9500 Communicator that allows you to create diashows of your favorite images. Specify up to 250 images to be shown (with or without a caption of your choice) and display them for a certain (customizable) amount of time, immediately or by using one of the 70 transition effects. Diashow also allows you to create very compact standalone diashow files which can be distributed to others without the need of including the original images (they only need the Diashow application installed on their Communicators).
Changes in version 1.10:
- Added more configuration options for image captions (font name, size, style, color and orientation)
- Multiline captions can now be created by inserting \n in the caption text
- Limited the maximum number of images for a single diashow to 250 to prevent out of memory errors
- Thumbnails are only saved if they are changed
- An information message was added when saving thumbnails
- The last opened image folder is now stored in the INI file
- Backcolor and delay for images in the diashow are now changed when the Diashow settings are altered
- Improved error checking and error handling throughout the application
Bugs fixed:
- Fixed "Overflow" error when creating a standalone diashow
- Fixed "Access denied" error when opening a diashow
- Fixed "String too long" error when creating or opening a diashow
- Fixed the problem that very large image files could not be opened
- The thumbnails of the current diashow are now saved before creating or opening an other diashow
- When previewing an image or diashow, corrupt or non-existent image files are skipped and no longer crash the application
For more information and download, visit http://opldev.broeze.eu or http://www.pdanet.ch.
