File sharing via Wifi
35 replies · 42,345 views · Started 16 July 2006
(first post, be gentle! 😊 )
I've just got my first symbian phone this weekend and i cant for the life of me get the file sharing working!
I have got the N80 browsing the internet via my wifi connection ok but i cant seem to share files between it and my laptop, these access the internet through a 3com wireless router.
I've set the sharing of folders on the N80 and the home networking icon is in the gallery but all it says once selected is "attempting to connect" (IIRC!), and just seems to not find anything, just sits there. 🙄
I have setup a file to share on my laptop (after running the file sharing wizard with my XP Pro).
I have also enabled uPNP on my router, dont know if i really need to but anyway...?!
Where do i take it from here?
Any help appreciated!! 😊
duckson wrote:(first post, be gentle! 😊 )
This has already been answered in another post by N/A
Not unless you install a web server or some other kind of file sharing server on your phone. Not many of those around, though.
You can howerver use bluetooth to browse your files of your N80 on your PC
OK cheers.
Whats this "Orb" program, could this be used in some way?
I have a Bluetooth usb dongle but its a bit slow of course, much faster via USB cable or by putting the miniSD card in the laptops card reader but of course file sharing over wifi would be handy.
duckson wrote:OK cheers.
Orb is a file streaming program on your pc that you access via a webpage, lets you watch your video's or live tv, or play music or look at your pictures, I dontthink you can actually transfer files though, would be nice if they implemented this feature
Hi!..
i think that you need to learn more about Upnp ...
The N80 has it ... so .. i am using UPNP just after i bought N80 😊
Install a Upnp "Home Media Server" app on your PC ... That´s all you need...
Then you will find your "Home Network" (on Gallery) ... then you can share, show or play files on the Phone to PC and download files on PC to the phone.. all via WLAN Upnp ...
On Gallery you can see options over any file "Play on Home Network" .. that means that your file will be showed or played at your PC at a direct streaming by WLAN ..
You can also copy that Shared files on your Media Server (PC) to the phone.. as you can also see when you browse that files on your phone "Home Network" on gallery ...
Anyway.. many options... Upnp it´s really great technology and N80 was the first Smartphone with it in the world ..
I am using "Simple Center" app on PC and work fine .... but i see that "TVedia" it´s better... i´ll test soon...
cya!
Great info, and good news 😊..will give all this a look 😊
Unfortunaly not all of us are tech savy as far as computers and especially networking is concerned, we can only forward what I have learnt through other posts on this forum, untill somebody with greater experience in the field has something to add 😊
Is it possible to add your N80 to 'My Network Places' in XP, there is an option to Hide/Show networked Upnp devices.
I have enabled Upnp in the Router settings & tried to add a new network place but can not get this to work.
Am I looking at the wrong thing?
See aefox pst above, seems you need to Install a Upnp "Home Media Server" app on your PC to get this working
I've been trying to set the file sharing up with XP without success.
I cant get my N80 to see the network, in Gallery -> Home network it just says "waiting for devices" without connecting to anything.
I have enabled uPNP on my router.
Is there any free programs like Simple Centre?
give this a try
Windows XP Service pack 2
Choose Control Panel for the Start Menu.
Choose Windows Firewall.
Select the Exceptions tab.
Click Add Program.
Select Browse, and locate Home Media Server on your hard drive. Double Click Home Media Server.exe.
Click Add Program.
Select Home Media Server, then click OK.
Repeat steps 1 to 7. However, at step 5, make the following change:
Again select Browse and locate Home Media Server. Double click on Silent Home Media Server.exe.
Service pack 1
Launch Home Media Server.
Once Home Media Server has started, open the Settings panel by clicking the Settings icon in the right top corner of Home Media Server window.
Click the Server tab.
Note the four port numbers displayed on this screen, in the Firewall Information box. Note: If fewer than four port numbers appear on your screen, close the Settings window and then reopen it. This box should display four port numbers.
Choose Control Panel from the Start menu on your computer.
Click on Network & Internet Connections. Note: If your Control panel is set to Classic View, choose the Network Connections icon. Then skip to step 9 below.
Choose Network Connections.
Select LAN or High-Speed Internet.
Select View Status of This Connection from the Network Tasks panel.
Select the Support tab.
Note the IP address.
B. Next, configure your Windows XP Internet Connection firewall:
Choose Control Panel from the Start Menu.
Select Network & Internet Connections. Note: Again, If your Control panel is set to Classic View, choose the Network Connections icon. Then skip to step 5 below.
Select Network Connections.
Then, from Network Tasks, choose Change settings of this connection.
Select the Advanced Tab.
Click the Settings button.
Click Add... .
Enter the following information:
Description of service: Home Media Server port 1
Name or IP: Name of your computer (This is the information you noted in Step 12A, above.)
External port: Enter the first port number that you noted in Step 4A at the top of this page.
Choose TCP port box.
Repeat the first 8 steps (in B, above) to add an additional service:
Description of service: Home Media Server port 2
External port: Enter the second port number that you noted in Step 4A at the top of this page.
Repeat the first 8 steps (in B, above) to add another additional service:
Description of service: Home Media Server port 3
Repeat the first 8 steps (in B, above) one more time, to add another additional service:
Description of service: Home Media Server port 4
External port: Enter the third port number that you noted in Step 4A at the top of this page.
Sorry to sound like a n00b (i am a networking n00b, only had a router for 2 weeks!) but when you say Select Browse, and locate Home Media Server on your hard drive. Double Click Home Media Server.exe. you mean a Home Media server piece of software that you've d/l or is this a particular program within XP and if so where exactly?!
I have XP with SP2.
Thanks for your help on this, much appreciated. 😊
PS will i need to open any ports on my router as well like the ones file and printer sharing is using?
Cheers Dx. 😊
I notice the home media server side of things is only free for 30 days, did you buy this software?
O well i'm stumped cant get this working. 😞
Should i be able to connect the home networking through the Gallery -> home networking option at least cus i cant do this even?
Hi!...
Just after you install "Simple Center"... you need to add some files to the main media library on the app ... then you will see that files on the N80 Home Network ... of course you need to keep running the Simple Center on PC ...
On DEVICES option on the Simple Center you will see the Nokia N80 detected ... and if Sharing Files are ON at the Home Network setting on N80 .. then you will see those files on the PC Simple Center...
Don�t know what else to tell you ... i just did those things and it�s working good...
good luck!
AEFOX wrote:Hi!...
good luck!
These steps are the only ones to follow, just do it and everything will b fine
AEFOX and Dx, i've added the files (it prompts you when you install it) but in Simplecenter there are no devices found in the devices section even when i try to find some.
I dont have Windows Firewall running and i've tried disabling the firewall in my router but still no go, i dont have to open ports on my router do i even if i have the firewall disabled (i'm a networking n00b so please bear with me!)?
Although as this is within the home network i shouldnt have to do this right?
It could be my phone not detecting the the home network some how (i can surf via Wifi fine though)....even if my PC with Simplecenter is OFF should i be able to connect to something when i select home networking in Gallery? cus all it ever says is " waiting for devices ".
I have the same problem as you duckson.
i can surf t`internet through my Linysys router but i can`t get my n80 to connect to my laptop, it just says "waiting for devices".
i`ve actually give up on it, might even reposess my "old" n90 from the mrs (great vids, tomtom, )
I can only think it must be a router setting?
How have you lot got the WLAN network setup? Infrastructure or Adhoc? mines on Infrastructure.
duckson wrote:AEFOX and Dx, i've added the files (it prompts you when you install it) but in Simplecenter there are no devices found in the devices section even when i try to find some.
ok, u gotta have simple center opened on ur computer, on ur n80 go to conectivity - then click on he redhouse icon(i dun remember the name lol) then select settings, click on share content, select your access point in the option below, then open simplecenter and try to see if ur phone is located
cheers
Dx
Dx, i did exactly as you say which i have been doing all along.
BUT i have now got it working to some extent, i didnt do anything different to what i have been doing though...didnt alter any settings etc!
Only thing i have done is reboot my phone a few times when i was messing with GSM and dual mode setting...although this had likely nothing to do with it the phone rebooting might of sorted it out, not really sure why its decided to work now!
However, I can only view files in Simple center from my phone and i cant view my phones files from simple center....also i cant transfer files from my phone to the pc but i can transfer files from PC to phone.
u gotta enable file sharing on ur N80, go to
conectivity>(the red house icon lol i dont remember the name)>settings
select the first option and fill al the info that it asks u
then go back to main menu and select share contet and enable sharing on videos, music
that should do the job
cheers
Dx
Ah yes, i disabled it when i was messing with it trying to get it all working. 😊
It wouldnt pick up simplecenter again tonight but a reboot of the phone and it picked simplecenter up without me changing a thing....maybe other people having the "waiting for devices" message should try turning the N80 off and on and trying it again.
