GPS NAVIGATOR is hidden on 3rd edition..heres how..
12 replies · 4,845 views · Started 02 August 2006
in order to get GPS navigator on your phone you need TASKMAN
under taskman-->misc--->options--->show hidden apps & show all preinstalled file...
then go to the "installed" function, u'll just scroll down, u'll see applications installed under Memory and Phones.. and there you go, GPS NAVIGATOR !!
blkcliostu wrote:in order to get GPS navigator on your phone you need TASKMAN
hi,
thanks for advice on this hidden app - although i found it ok it drops the bt connection after about 10 minutes on a journey - just like other GPS apps
i am using the official Tom Tom Gps receiver
anyone alre experiencing this.?
Im still waiting for my gps from my mate will test when i receve it
ok, found the app, but is ther anyway to acess the app from a menu as taskman is only useable 4 15 days
I was thinking of making a shortcut to the file on Z:\sys\bin\nav.exe etc..... and saving it on memory card.
But when browsing Z using a few different file explorers you cant see the sys folder!
I have had my phone about a month and have never even noticed this taskman thing, where is it? Or does it completely dissapear after the 15 days?
elaverick wrote:Actually all you need to do is assign a voice command shortcut to it and you can run it via that.
I tried this, and to my supprise, whilst adding new voice command, Positioning was actually in the list, not hidden atall.
However, 'Positioning' is just the settings, it is not the 'Navigator' app that i want a shortcut to.
TechnoMan wrote:I have had my phone about a month and have never even noticed this taskman thing, where is it? Or does it completely dissapear after the 15 days?
Anyone?
Taskman is a third party application (see the software section on this site) - trial version only lasts for 15 days.
