So I tried ringing somebody to find my contacts list refuses to open, I can see it when I am wanting to add a contact to a text message, but if I try to open it from anywhere else it flashes Contacts up the top as its about to load then boots me back to the first screen with shortcuts and clock on! tried turning the phone on and off but still nothing... anyone have any ideas? im running the newest firmware in the UK I think well thats what came with the phone
stuck! I cannot access my contacts!
Reset the factory settings in the tools menu should sort it out, mite loose all data from the phone.:frown:
I had the same problem after backing up to PC suite, A simple Off/On sorted it.
Well funnily enough, I dont know why but something kept shouting at me in my head, its the Theme your using mic, so I changed the theme and its worked since, very very strange it was an N80 theme I downloaded and was working fine for about a week!
ukmic wrote:Well funnily enough, I dont know why but something kept shouting at me in my head, its the Theme your using mic, so I changed the theme and its worked since, very very strange it was an N80 theme I downloaded and was working fine for about a week!
Same thing to me, theme related, and N91.
