N80 - Mini-SD Compatibility
10 replies · 4,094 views · Started 16 August 2006
I seem to be having problems with my 2Gb Sandisk card like a lot of other people.
I would like to sell this card and purchase another but i have found no definite answers on what card to get. I have heard the AData ones have been working very well?
BTW - I dont want to mess around doing the format trick in windows, copying files from original nokia card etc because this still seems to cause problems based on other peoples posts. AND i'm not paying nokia �54 for a 1Gb card !
Can people post up either WORKING or NOT WORKING ..... I have ...
NOT WORKING
2Gb Sandisk Mini-SD
V 3.0617.0.6
03-05-2006
RM-92
Nokia N80 (31.01)
Issues - Card works for < 1 min and then says 'no mem card inserted', supplied 128mb nokia card works fine.
I think this would be great info for everyone.
Cheers!
bigmouk wrote:Sorry, just found this thread from a couple of month back although i think it would be good to get a consice thread where users can quickly glance at the card options.
http://www.allaboutsymbian.com/forum//forum/thread/47630/&highlight=memory
Do you have a genuine scandisk card, or did you buy from ebay..there are many fakes that just dont work there ....I have scandisk card and have no problems at all, I bought in a shop and that obviously reflects in the cost, but at least I know its genuine and I can get my money back if it goes faulty
Possibly not genuine (looks genuine), How can i tell ? Bought it from ebay. Works fine in my digi camera though?
bigmouk wrote:Possibly not genuine (looks genuine), How can i tell ? Bought it from ebay. Works fine in my digi camera though?
I am guessing its not genuine if you bought from ebay..its well known that there are many scandisk fakes there,
Not sure how to check either, but if it was cheap it is probably fake...its always a good way to tell.
I heard people have problems with the fake cards, but didnt yet hear anybody have problems with genuine cards.
Thanks for the info Cash. BTW - has yours got any numbers/stickers or anything on the back of the actual card ? Cheers
Update - Yep, its fake. Just rang Sandisk. That obviously explains the problems and probably everyone elses with a sandisk from ebay.
I bought a sandisk 2GB of ebay for �32, I then realized it could of been a fake (first time buying a card) I recieved it and had it working fine, I emailed sandisk with pictures which they said it was fake as it didnt have a code on. The card itself has been fine and I have used it for over a month now, have about 1.5 - 1.6gb left not a hitch, none of this "no memory card inserted" it has been perfect. So either I have extremly good luck! or its actually genuine and sandisk are stupid!
I bought a no name one off ebay for a bit under �15 and its been fine. Didnt spend a great deal on it in case there was a problem but all it has to do is work and Im happy. If I ever have to replace it then Ill get another cheap one. I back up all my stuff on my laptop each night anyways so I wont loose anything if something happens. My last phone had a 512MB MMC card which was also no name and it never failed so I bought this mini SD from the same people. I dont see a problem buying cheapo ones from asia as thats where theyre made anyways. I wouldnt buy a branded one like sandisk or sony or anything because the fake ones might be of different quality and I too have heard of issues with branded fakes.
