Troubles opening MMS - phone got slow
6 replies · 2,133 views · Started 03 December 2002
Hi to all,
my phone got much slower in opening MMS and other media files. It needs nearly 1 min to open a MMS, the same with sounds or pictures I sent by IR. No problems to save them then, and once the files are saved, I can open them very quick, less than 1 sec. Besides of this the phone works very well, no crashes or something like that, and I have about 1 MB free mem. Any idea what could cause this problem? Perhaps there is a temp folder which is too full? Thx for ur help in advance!
Do you have lot of messages in your phone?
I had quite a many, and it became slow too to open anything there.
Try deleting, you can transfer your sms messages & emails with the
messageSaver app first.
Ok, on my phone there was about 50 sms and 15-20 emails and it was
not terribly slow even then. So its not that then. :-? No ideas anymore.
It may help if you clear the communication log. You may also want to set the Log duration to 1 day do that it automatically clears every day.
I have no ideas to help to Freddie, but PLEASE could you put a link for MessageSaver app? I didn�t know anything about it... 😞
Try this place (developer):
http://koti.phnet.fi/jarilaak/software/index.html
also in handango for sale.
