Guys,
do any one of you is facing this problem. I have around 140 songs stored on my E:\Songs folder. When i go to Music player and then try to update the songs i get a small windows saying "Updating" and finally it quits saying 0 tracks removed, 0 tracks added. Because of which i am not able to play anysongs on my N80.
Recently i upgraded by Firmware to v4 (Euro1 black). Any of you facing issues. Is there any workaround to get this working. Appreciate your help!
~Vince
Not had this problem myself.
I did get a brief moan from the phone about memory card changed, but then it picked up my library correctly. This warning was probably due to me removing the memory card from the phone during the flash.
Have you tried going through the "eject card" routine, reinserting and retrying the library update?
maybe you need to put them in the /sounds folder ?
Jaffa-cake wrote:maybe you need to put them in the /sounds folder ?
I missed that - good catch...:icon14:
Guys,
thanks for all the suggestion....But i figured out that all the music files where in the "hidden" status. Once i changed the attribute back to normal, i could update the music files successfully..
thanks again!
~Vince
vin_eme wrote:Guys,thanks for all the suggestion....But i figured out that all the music files where in the "hidden" status. Once i changed the attribute back to normal, i could update the music files successfully..
thanks again!
~Vince
Hey Vince - How do you change the attribute?
what was hidden and how did u change things please
