Installing Route 66 on the Nokia N80
10 replies · 6,429 views · Started 29 August 2006
I have followed the instructions as it says, copied the system folder over followed by the map, as there is already a system folder there, it was overwritten, but when i restart my phone nothing has changed, no icon and all my other stuff still works, almost as if i have done absolutely nothing!
Anyone have any advice for this?
Tar
nj7 wrote:Wich software version You have in your N80? Only works well with last one.
HI, guys, I have the same problem, I download Route66 Mobile 7.0.989, and copied the folder to the root of the sd card ,then inserted into the mobile and rebooted. Nothing happened!
BTW, How to check the version of N80, and what's the latest version and can I upgrade in Nokia official website? Many thanks!!!
wuhanzyg wrote:HI, guys, I have the same problem, I download Route66 Mobile 7.0.989, and copied the folder to the root of the sd card ,then inserted into the mobile and rebooted. Nothing happened!
To check version: *#0000#
The latest version: v4.0623.0.41 (in Europe anyway).
Upgrade via Nokia's Software Updater - not yet but shortly: keep an eye out here: http://www.nokia.co.uk/nokia/0,1522,,00.html?orig=/softwareupdate (UK specific link)
Route66 Mobile 7.0.989 doesn't work over Symbian 3rd edition devices. Nothing happened! = normal!
auato wrote:Route66 Mobile 7.0.989 doesn't work over Symbian 3rd edition devices. Nothing happened! = normal!
Which route 66 does run on the n80 then?
I don't have R66 anymore as I sent it back for a refund when it did not work properly with N80 FW 3.0617/3.0618...
... however, the version number for R66 was Mobile7.3.468
I assume you need that version or even higher.
p.s. The GB map included with the above version was corrupt, and would cause the program to crash when calculating routes that included the corrupt parts of the map. R66 apparently has new maps available to registered customers.
Hope this info helps.
Hi, I managed to install Routte 66 7 on the N80 with the latest firmware, there are differents file to install not only the one on the system folder, I can start the program from My Own folder but I don't have a working serial, I am not using a genuine copy of the program at the moment.
I will let you know once I am able to use the software.
I don�t have the N80, but for others said on foruns, the Route66 program only run, if is the last Route and, like "TazUk" said, with last N80 firmware. Someone had said, that was Nokia that solve the problem, when release the last firmware.
