locking the keypad
21 replies · 5,853 views · Started 04 December 2002
is there another way to lock the keypad on the 7650 other than sliding the keypad down coz when the phones in my case i can unlock the keypad make a call but then i have to take it out the case to lock the keypad !! all this technoligy there must be an other way way but i cant seem to find it so i turn to you 😃
i don't know if this is what you're looking forl, but there is this appl called keylock. it automatically locks your keypad when you push it down! no asking if you wanna lock it up or not!! this appl will do it for you!!
Locking with Power button is locking the phone with a Passcode. What xzibit is looking for is a way to lock the keypad without having to slide it open and then shut it.
Strange no one thought of this erlier. Its pretty useful actually.
Yes pressing the power button gives you the first option of locking the phone. Push the joystick up one, and you get the option to lock the keypad. Looks like someone did think of it, you just need to know where it is! 8)
[quote="JyriK"][quote="sanjay2402"]Oops!! Found it!![/quote]
😃 what? 😃[/quote]
Jyrik .. Jyrik... 8) :black: 😃 😃
[quote="sanjay2402"]So, here's my 300th Post 😃 😃 :angel: :angel: :angel:[/quote]
Welldone.... guess i only have 299 to go to catch up! :angel:
[quote="chris021"][quote="sanjay2402"]So, here's my 300th Post 😃 😃 :angel: :angel: :angel:[/quote]
Welldone.... guess i only have 299 to go to catch up! :angel:[/quote]
You are still one ahead of me. I started off at Zero 😃
You can also use SeleQ, it has a way of bypassing the lock question, but you have to have it running in the background though.
i know... autolock, powerbutton...
but is there any application that only locks without powerbutton and keypad open/close?
so i can put to favourites of activedesk.
dont want to press the powerbutton
Hi the file keylock.sis is not there anymore. It says it doesn't exist?
Any idea where I can find it now? Searched the web. No Luck 😞
Ok I found it 😃
Can one of the mods please tell me if I can upload the file.
It's freeware as far as I know? :angel:
You can post it.
But it should be somewhere here, allready, as I posted it a few weeks back.
But post it here.
Thanks Jyrik
I posted in this forum
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=8748
