Nokia N80i announced, adds software package
19 replies · 5,752 views · Started 31 August 2006
Nokia has announced the Nokia N80 Internet Edition a software enhanced version of the N80. The N80i bundles extra software including Yahoo Go!, Flickr Integration, WLAN Wizard, Download! (Catalogs), Mobile Search and Mobipocket to give a more complete out of the box experience. The hardware specifications remain the same with quad band GSM and WCDMA radios, a 3.0 megapixel camera, and IrDA, USB, Bluetooth and WLAN connectivity.
Can existing N80 owners download all this software? :P
Odd that its a software update.
Nothing new on the software front - it's all out there already.
I like the sound of the Bronze finish though..
It will be interesting to see whether there are any 'hidden' improvements for example to the camera or memory optimisation.
In the past with 'i' versions of Nokia phones it has not been possible to upgrade existing phones to the new version, however if as stated there are no 'hardware' changes then surely it will be possible to flash existing N80's with the N80i software.
Time will tell.....
If you read the full press release it also mentions about 'voip'
'Making an Internet call with the Nokia N80 Internet Edition is as easy as making a regular voice call only the call is carried over WLAN. The VoIP framework (based on the SIP protocol) is integrated into the Nokia user interface, and the Nokia N80 Internet Edition is allows for downloading compatible third party internet call applications.
previously although you could enter sip settings only the e series phones had the voip function
The N80 currently only has WCDMA 2100, not 1900+2100. I do not think that the N80i, which seems to only include software upgrades, would add another WCDMA band. A different version of the N80 (N80-3) was planned to include 1900 for the USA but it is as yet unreleased.
My apologies on the band mistake. It has only one. The N80i like the N80 is 1900 or 2100.
I think most of that improvements can be done with 3rd party software. Hope this new N80i could make the regular N80 become cheaper and buy it 😊
Hmmm, interesting I'm curious that is there any hardware changes, and also, will Nokia maintain two different firmwares for 'normal' and internet edition' N80s...
Rafe wrote:My apologies on the band mistake. It has only one. The N80i like the N80 is 1900 or 2100.
N80i:con?
Taz: Thanks but I'd found that. My point was that the N80 isn't supported yet. I understood from your earlier comment that it was. The link shows it still missing as a supported phone.
There is no such thing as the N80i. The press release refers to the product as 'Nokia N80 Internet Edition'. So i assume its ike the N93 Golf edition. Same phone(N80) but with some extra software already installed.
fdxd wrote:There is no such thing as the N80i. The press release refers to the product as 'Nokia N80 Internet Edition'. So i assume its ike the N93 Golf edition. Same phone(N80) but with some extra software already installed.
Yea... Marketing, nothing more.
nj7 above has to be right. The existing N80 is essentially out in typical Nokia 'public beta'. There is no way it can be a new model per se. The N80 is basically unusable for VoIP and SIP as it doesn't have a useful battery for starters. If you want SIP, a decent battery and some degree of debugged OS, then get an E61. I threw my N80 back a day after getting it.
Yes the N80i is a marketing excerise. I was a bit suprised to see it referred to as the N80i on the Nokia site (check out the press pictures for example) as previsouly marketing led phone hadn't used this shothand.. e.g. Nokia 6630 Music Edition
Nokia never refer to the Nokia N80 Internet Edition as N80i on their press site even. Its not a new phone launch its a software package with the phone ala 6630 music edition and N93 Golf Edition. I assume this replaces the normal N80 package.
it's not necessary to instal third party voip software to reap the benefits of the N80i 's SIP compatibility. if you're in the UK, it's as easy to use voip on N80i's as it is on E60's. afaik aql.com are the only people who provide OTA configs, which is the simplest way to get started with voip. hopefully more nokias aqcuire those "i" features.
