Does anybody know when it will be possible to upgrade to v4 on O2?
Firmware upgrage on O2
It already is, I updated my firmware myself a while back without a hitch the hardest thing was installing the software correctly! I just used a generic firmware, didnt have to back anything up didnt lose a thing either just installed and that was that.
yer im on o2 and upgraded to v4, u can upgrade and not loose any settings but then u wont get the pdf viewer and virus scanner.
but the other way gives u them 2 apps but loosed all yer settings
Doesn't using a generic firmware invalidate the warranty on the phone?
it only invalidates yer fone i believe if u flash it your self regardless of if u find a o2 one.
if u goto carphonewarehouse etc since there approved or somet by nokia then you wll keep yer warranty.
cah1982 wrote:it only invalidates yer fone i believe if u flash it your self regardless of if u find a o2 one.if u goto carphonewarehouse etc since there approved or somet by nokia then you wll keep yer warranty.
Yeah but that's the problem Carphonewarehouse and Nokia will not flash my phone because O2 haven't yet approved v4 firmware!
:frown:
